Yeah ok, I will connect the fan to my fancontroller and keep an eye on it, I will check the computer anyway as it's a new system (still without a CPU though at the moment)Yewen said:SHOULD be fine, just set the other one to maximum first.
Just keep a eye on it really for first few minutes.
No reporting on the fancontroller and I don't care what rpm the fan is running at, I just want the fan as quiet as possible.Yewen said:Im saying should only as it might be some freaky fan; done it with others just fine.
Just not that particular type. Only slight thing is the fan controller if it reports speed might be slightly off.
