I tried to adjust the tension on my chain yesterday as it was quite slack. I realised that my adjuster blocks did have a marker in the middle which was a bonus! (Had thought they didn't as they are differen either side)
However just when I thought I had it right I would tighten it all up give the rear wheel a spin and find that there was a spot where the chain tension would increase quite tight and stop the rear wheel spinning freely. If I kept turning the wheel past this point the tension would ease and the chain relax to a healthy level of movement. What could be causing this?
I ended up leaving it still fairly slack as I didn't want to put unnecessary tension on the chain.
Thanks,
BennyC
Thanks,
BennyC
