Adjusting Clutch Bite Point?
probably a stretched clutch cable? check down near the oil filler cap,see how much thread is left on the end of the cable,if theres a lot you can undo the locking nut and adjust,then you can screw the adjuster back in at the clutch lever end
Thought the GSXR's were piston operated?
Either way, if piston, bleed it out, if cable, read above.
Also, by end, you mean lever out or in, out means it's very sharp, in means its very slack.
