Adjusting Fan Voltages
27 Feb 2006
Normanton
I'm looking to quiet down a few of my fans and was wanting to know which resistors I need to buy to acheive this.
The fans in question are the ones bundled with the antec 1200 case so the big one on the top and the 5 120mm fans.
I know you can turn them down as standard but even when there all on low there still a bit loud for me as everything else is silent as its all watercooled.
I dont want to replace them really as I like the blue glow they give so any ideas on what I can do to cut the voltage slightley more would be appreciated.
Cheers :D
a fan controller is better than adding resistors, alternatively, if you watercool EVERYTHING (not only CPU and GFX but also NB etc.) then tie them of so they cant spin but still give pretty lights
