Admiral multicar
28 Oct 2006
Cambs/Florida
Hi there, I am currently on a admiral multicar and I am just running some quotes on other cars. I am thinking of buying a nissan s14 200sx they will quote me on the normal 200sx but the 200sx touring it comes up with the message saying you need to be 21. As far as I understood it I thought the cars were almost the same? Any reason why they do this?
Cheers Phil
Probably down to statistics alone. The touring model is the desirable one (I'm not even sure if there is a non-touring S14A?), and thus there are probably more of them crashed.
Phone them, they might have a bit of flexibility as you are on a multi car.
no harm in phoning but its likely that its his age/vehicle i doubt there would be any flex in their decision, otherwise how would it be fair to all their customers to let one person have the vehicle on cover and not someone else
Fair got nothing to do with it,its a business, if they are getting something significant out of the multi car they might flex.
Its like anything when you buy the 5th diamond off me your gonna get it cheaper than the first one.
not if its a high risk, they not going to say "ok you got 4 cars with us, we dont normally cover a vehicle of this type but as its you.........ah go on then"
whether the policy costs £1000 or £4000 for all the cars, they wont change their decision incase the young driver puts the high risk vehicle in to a bus stop and they pay out quite a bit*
* this is an extreme outcome but it has happened
I am going to give them a call because there is a lot more mint ones that are s14a, I have around 4k to spend so should get a good one for that money!
I just gave them a call. The touring so the s14a is more of a risk than the s14 which is stange. It just means if I want to get one I will have to look at the s14.
Quite a way, I may just wait till my next year no claims is up in september meaning I have two years then my sister works at adrian flux and she ran a quote with one and then with 2 and it didn't really make that much diffrence was £1500 now or £1100 with 2 years. I am in the multicar with admiral at the moment and paid the whole ammount up front so I guess I am stuck there. I have always liked the s14s go to a lot of the drift days with friends but decided I want to get one now.
This is what I want being picky!
S14 200sx
Has to be newer than 1996 because I have a "p" private plate,
No VVT rattle and no rust!
No completely modified just a few little bits.
I don't think I am going to find it easy to find the right car.
Admiral are quite silly when it comes to what they'll insure under 21 and what they won't.
Absolutely no chance of getting insured on my car if it was registered as a Lexus, but as a Toyota no problem. The best one I've come across is them not insuring me on a GS300, but they'll happily insure me on a more powerful, more vaulable, higher insurance grouped GS430. That made perfect sense.
Good luck with the S14 hunt :)
I really do think they just pick the cars out of a hat. I am just going to wait for the right one to come up but it's very difficult as most of them a s14a touring I just need a s14 200sx not the touring. I have a bmw 323 so should be a nice little upgrade to me, I guess some people will say it's a downgrade but I want a turbo car that I can play about with and if and when modifiy if I want.
