1 = Choose Output from the tabs at the top. Then browse and select the photo(s) you want.
2= Click where it says PDF. Underneath that, in the Template drop down list, select Maximum Size.
3= This is where you choose the page size. To make sure there's no letterboxing, you need to make sure the aspect ratio of the page matches the aspect ratio of your photos. SLRs are 3:2 and Compacts are 4:3, exact ratio may differ slightly from camera to camera so you might want to work it out yourself.
4= This is the page border setting, make sure all four are set to zero. Just under this, there are options for Overlays, make sure all these are deselected.
