Adobe CS3 users!!!
30 May 2004
Uk
What would you recommend as a minimum spec pc to run CS3 well? I know what they advise on their website but I take that with a pinch of salt.
Cheers
I used to use PS CS3 on an Athlon 2100+ with 1GB of PC3200. Took a few seconds to start up and anything like filters took a bit longer but it wasn't too bad.
Depends what you're going to be using it for really. If it's just small and simple web graphics, you should be able to get away with running it on a pretty old machine.
It will be used for clothes design (not by me obviously) so will probably be handling fairly large files and really needs to run without much slowdown or long waiting times.
cheers
