Hi, I've had a string of probs with freezing / lock-ups on this new rig since I built it about 6 weeks ago. At first I thought it was RAM related but I discovered that they only happen when I'm browsing on-line and after a lot of trial & error I've pinned it down to a problem with Flash Player (I think).
At first I thought it might be FireFox 4 (which I use all the time) but it happens in exactly the same way in IE 8 as well.
Tonight I uninstalled Falsh Player (V.10.3) as an experiment and had no problems at all when browsing (other than not being able to see any Flash vids). I then downloaded and installed a fresh version from Adobe and as soon as the adds started on MSN home the PC froze. Sometimes it freezes and locks-up completely and at others it re-boots.
Does anyone know why this should be happening?
PS I'm using a fairly recent fresh install of Win 7 home 64 (Retail) which is fully updated + SP1. However, the same thing happend when I was running this PC previously using an ISO image of Win7 on 30 day trial.
Everything else works absolutely fine. It will play music all day and night / run back-ups, go to sleep + wake up etc. all ok.
I'm baffled (and annoyed)
Has this happened to anyone else?
