Adobe Premiere CC : Reversing Auto Contrast.
Caporegime
8 Nov 2008
Hi,
As above. I've enabled that on each part of the video, but due to the insane encoding time it appears it will take, I've decided I want to remove it. Unfortunately, I'm past the point where I can simply 'undo' the action.
Is there something else I can do to remove that effect?
Thanks.
You will have to select each clip you added it to and in the Effects Controls panel, you will have to select and delete the Auto Contrast Effect. Prem is annoying in this respect
Thanks for the reply. Luckily, I just happened to stumble across that solution a moment ago. Phew! :)
Beautiful pics in your portfolio, btw. :cool:
