Adobe software install problems
30 Apr 2008
Basically my friend was having trouble with his laptop keyboard which was fixed with a system restore. After the restore he couldn't access adobe premiere cs4 or after effects. So we un-installed them and tried to re-install them and the setup fails every time. We even used the adobe cs4 cleaner script from their site and removed everything and the install still wont start?
Any ideas?
Thanks guys
Did u deactivate cs4 before un-installing? That can cause issues as far as I am aware.. might be worth contacting adobe tech support, I've found them helpful in the past although not always easy to speak to someome...
Try running setup with administrator privileges
edit: Altho re-reading ure original post I think this might not resolve ure problem, sorry..
