Adrian Mutu
Maybe I'm being naive but I'd have thought it wasn't all that hard to avoid taking banned substances (or drinking/smoking/eating unhealthily for that matter) for the duration of a professional playing career, it's relatively short but you've got an awful lot of time to fill after it's over - why not make use of it?
I've never quite understood why they check for recreational drugs, but this one seems to be a performance-related substance. Used for weight loss apparently. Clearly someone's getting a little porky.
:D
He owed Chelsea a shed load of money ! Then goes and does this :D
Silly people like him are what makes football so much fun sometimes.
Errm, http://en.wikipedia.org/wiki/Sibutramine ,
its basically, as it says there if accurate, not an abuseable drug and isn't really required to be a controlled substance.
From what I can tell, its got potential for a similar effect to an antidepressant and an appetite supressor, it also mentions it has a half life of 1 hour so I can't imagine you can even have it in your system for all that long. Although whatever its metabolised into maybe stays in your system for a while and thats what they tested for.
But, its not a performance enhancing drug, doesn't seem to be anything more than a possible serotonin increasing substance.
So before you all jump all over him, about the worst thing the substance does is supress apetite, should we really be banning people for that. Not quite sure how its helping him beat the opposition, nor is it a narcotic. I really can't see a reason its banned in the first place other than being a fairly risky drug in terms of side effects and complications.
This isn't a "bad" weight loss drug that raises your metabolism and maybe gives you more energy, like ephedra or something, its something that just helps to suppress apetite. For all we know he's had a life long problem controlling his weight which obviously for an athlete is a problem, maybe he suffers from depression due to the pressure to maintain weight, who knows. But the drug simply is not giving him any advantage on the pitch, nor is he abusing cocaine, which also won't give him an advantage but is bad for the "image of football", obviously ignoring letting Marlon King and Barton continue to make money in football.
I think the point is that regardless of the merits of whether any particular drug deserves to be banned or not, it is the responsibility of professional sportsmen to avoid taking them.
Obviously with the huge debt hanging over him, I suspect Mutu doesn't really have a massive incentive to retain his 'license' to play though, as presumably the vast proportion of his earnings go to Chelsea anyway.
The worst thing about this situation is the fact that his Fiorentina teammates backed him to the hilt & offered him financial support when his court case with Chelsea was resolved.
He's obviously in a bad way :(
Indeed a real kick in the teeth for people who tried to help him re: the Chelsea situation.
He's being suspended while they decide what to do with him, could face up to four years banned.
