ADSL, Fax & Franking Machine
23 Dec 2009
Earth
If I plugged all these devices into the same phone connection would I be asking for trouble? I used to have two lines but got rid of one to save on costs.
I know fax lines can cause issues with ADSL but so far I've had no issues and now just the franking machine left to connect when I buy some more cables.
Whats the REN value on these? Thats the important thing. BT Supposedly supports 4.
Why have a franking machine? They are quite pricey, and offer very little in the way of savings.
Thanks for quick response, it is not my business just sorting out a few things for a another small company.
I would have to check what the exact REN values would be but if BT support 4 I think it should be ok considering no phones will be running off the connection.
I will see how it goes and report back if there are issues.
I think now there are machines available which may be used with Wireless connection. Internet can be used by Wireless system. Although this is not the only solution but this is really really important.
