Hi There
After a bit of help with ADSL as in the past i have allways used cable.
It appears that my dad has a BT Voyager 220V ADSL Router which he took from his old house and has recentley payed for a ADSL connection with BT. There are 2 problems with it
1. The internet dosent allways work, saying there isnt a strong enough signal ?
2. If the PC is moved say away from the ADSL source ( say in another room ) the net wont work at all therefor it has to be sat right next to the socket ...
Apprentley after speaking to BT they have said that because he lives in the "sticks" the signal isnt that great and that he will have to put up with it ? Surley either BT are fobbing him off OR there is something you can buy to boost the signal ?
I have bought home a Draytek Vigor2600VG ADSL + Voip Router/54 Mbps Wlan but all the above problems seem to still be the same
Some help is much needed and will be much appreciated
Many Thanks
Sam
Many Thanks
Sam
