I've just migrated ISP and ran a speed test since it seemed to be extremely slow.
The result was:
"Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 1000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3552 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 834 kbps"
Given that the downstream rate is much higher than the actual rate, is it likely that I will see an increase over the next few days as the config stabilises?
Thanks
The result was:
Thanks
