Right, my ADSL max has come into effect today - yet I'm not able to get higher than the 2MB speeds I was on, despite being connected at 7616/488.
I've tried speed tests and just downloading stuff - I can't get it over the 250KBytes/s I was used to.
Line stats:
I've noticed that my downstram noise margin is considerably lower than it used to be (though I can't put my finger on what it was - I know it was double figures), is this good, or the problem?
Any help would be appreciated, thanks.
Line stats:
As I said though, unless you reboot the router loads of times in a short space of time nothing should be affected.
