ADSL MAX Speed
19 Mar 2006
Scotland, UK
Hi there, Having been on AOL since i got my first pc about 4 years ago, I have recently been upgraded to their 8 meg service :)
I was on 2 meg before and enjoyed speeds of 240Kb/s on downloads.
Now I connect through a router as i can't stand the software they force upon people but since upgrading i havent noticed a speed increase.
My router quotes the figures of 3936Kb/448Kb as the connection speed, yet i still get the same download speed as before, but wiht higher pings :@
I have been on this for over a month now, so I am wondering whats up, it originally connected at 5446 instead of 3936, but i guess that was the 10 day period of trying to get stability.
Any advice?
What router is it? Have you tried doing a factory reset on it and starting from scratch? Have you tried any others, or just a straight ADSL modem?
I'm not sure if you still can, but it used to be possible to log onto a BT Speedtest ADSL login, if you can, give that a try. What are you using for your current speed tests? What's you upload speed looking like?
Routers are important imo, i had a linksys AG041 and best speeds i could get was 3 meg with highest sync i saw of 4670 when it first went live but always settled around 3900 mark(3meg).
I upgraded my router to a Netgear DG834G well i say upgraded my sister gave it me and my speeds gone up straight away, hightest sync i had was 6072, even managed 580kbs at one point, it settled at 4 meg speeds now though with syncs of around 5000kbs, but just goes to show a router can help.
agreed
i used to have 3 to 4mb speeds with my old router
now i have a speedtouch 585i v6 [which ocuk sell]
i get 5mb speeds, sometimes 6
The BT Speedtest will give you the IP profile you're on, which would give some indication of whether you had a stuck profile or just congestion.
If the 3936kbps sync rate is stable (or at least, doesn't go below 3424kbps), you should expect 3Mbps.
I was in a similar situation when I got upgraded to MAX. My router (DG834) was connecting at 8Mbps, yet I was still getting speeds of 1MBps, which was my previous speed.
Got onto my ISP (well, posted in a thread on the metronet forums) and they reset my BRAS profile or something and bingo. Apparently something had not updated at the ISP end. Speed varies between 2 and 7 now depending on the time of day (exchange is congested, I think)
So I suggest you raise it with your ISP to see if they can do anything.
It slways depends how far from you and how popular your exchange is...
That affects the speeds big time, im on 8mb and i have atleast 6000kbps at all times, usually just over 6500...
I think the problem is with the actual throughput not the connection speed :)
