ADSL Router / Wireless / Gigabit
31 May 2005
Alfreton,Derbyshire
To be more specific i'm wondering if anyone knows of or has an ADSL router that has at least 4 Gigabit ports and also has wireless built in (faster the better 54G Min)
I have just found
D-Link DGL-4300 108Mbps Wireless & Gigabit Gaming Router
Which requires an ethernet connection to an ADSL router still.....
But something like that, condenced into one device?
Routers with GigE built in are rarer than rocking horse poo, and mostly pointless (since a) no router at a price range you'd want to pay could route at gigabit speeds and b) no internet connection available for a looooooong time will be fast enough to be worthwhile) - you've got a much better chance of finding a (decent) device if you go with separate router and GigE switch.
As above, it would be better to get a decent internet router and a seperate gigabit switch :)
Thanks for the input, thinking in terms of just leaving 1 device on 24/7 instead of 2 really. I have a dlink 504 dsl router at the moment....So hooked up with the above gigbait switch + fast wireless. That should be ok?
