ADSL Stats Advice
25 Mar 2004
Iwade, Kent
I'm temporarily living with the in-laws whilst some major refurbishment work is carried out on a house I recently bought. Once we move, I'll not have any internet problems as a private leased circuit is going in (whoop!) but untill then I'm stuck with AOHell DSL.
The in-laws internet has never been stable despite a veriety of recent changes made by AOL/BTOR such as a replacement router, replacement microfilters and moving the primary phone socket.
In short, *something* seems to die quite regularly (e.g. every few hours) although is relatively quick (~30s) to fix itself but what ever resets seems to result in an IP change which is proving to be a PITA.
I've logged into the router (Huawei) and here are the DSL line stats:
http://www.axerite.com/jing/2013-04-22_1011.png
Not that the DSL circuit is showing as 18hrs uptime yet the net dropped about 5 minutes ago which has me scratching my head!
Any thoughts people? :)
There looks like a fault 65k crc erros in 18 hours is high and 16.7db snr also points to a fault with the line.
The line also has high interleave depth which points to a fault somewhere on the line.
Hi Locky,
Thanks for your response, what sort of snr should I be seeing typically?
Regards, Jon
I fitted an I-plate to the socket today which may have slowed down the errors, here are the error stats so far:
@ 12:35 on 23/04/13:
Downstream CRC 65504
Upstream FEC 429
Downstream FEC 65444
@ 13:40 on 23/04/13:
Upstream FEC 466
With that line you should be hitting 20Mbit if all is working ok.
SNR is normally around 6-7dB but can depend on ISP settings.
A couple of hours on and I see:
@ 15:40 on 23/04/13:
Upstream FEC 1621
I'm not sure how significant or not the increase in Upstream FEC is :(
FEC errors are fine and is something to do with Interleaving.
Kitz said:
Count of errors that have been corrected due to error correction being applied to the line. Error correction is turned on at the same time as Interleaving. Its normal to see FEC errors on an Interleaved line and rather than anything to be too concerned about its more an indication that the Interleaving & Error Correction process is working and doing what it should. - See Error Correction for more information.
More info http://www.kitz.co.uk/adsl/linestats_errors.htm
It's HECs and CRCs you have to be aware of.
Doh, thought I was making progress as to what the issue might be, back to the drawing board then!
These are the latest stats from my line, what are we thinking guys, any obvious signs of an issue?
@ 17:51 on 23/04/13
Upstream FEC 3788
@ 23:10 on 23/04/13
Upstream CRC 11
Upstream FEC 10004
@ 11:36 on 24/04/13
Upstream CRC 23
Upstream FEC 16389
