17 Feb 2007 at 18:00 #1 Rooky007 Rooky007 Soldato Joined 18 Oct 2002 Posts 3,683 Do some router reach further than others? As I was told they dont. the different are speed. I am not really up to tech on routers.
19 Feb 2007 at 07:58 #2 Rooky007 Rooky007 Soldato OP Joined 18 Oct 2002 Posts 3,683 Rookies said: Do some router reach further than others? As I was told they dont. the different are speed. I am not really up to tech on routers. Click to expand... No Help on this? Been trying to work it out this weekend. I though it just the speed that increase between the different wireless range like between G and N Or do one or other work further distance. How far should they both cover?
19 Feb 2007 at 11:12 #3 Mr-White Mr-White Soldato Joined 12 Nov 2002 Posts 14,600 Location In my own little world different routers have different radiuses, check the reviews before you buy. MW
