ADSL2 advice needed
24 Sep 2006
Hi
So I am currently on the standard ADSL24 service but am considering changing to the LLU one. But I am unsure if I will receive any significant improvement in speeds from such a move.
Can anyone help?
My current speeds are:
Speed Down 2378.46 Kbps ( 2.3 Mbps )
Speed Up 376.18 Kbps ( 0.4 Mbps )
My line stats are:
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,232
Output Power (Up/Down) [dBm]: 11.5 / 18.5
Line Attenuation (Up/Down) [dB]: 28.0 / 45.0
SN Margin (Up/Down) [dB]: 21.0 / 15.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 298 / 764
HEC Errors (Up/Down): 123 / 393
My line sync/profile information is here
Thank you ;)
Your SNR margin is very high. You'd get more, even on ADSL, if that was reduced (but it might result in instability).
I'm with 02. Here are my stats at 20.50 at night - think maybe I 'm about to be disconnected as I connected during the day - now much noise. My line will only take the lowest package:
DSL Connection
Link Information
Uptime: 0 days, 9:54:08
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,217 / 8,187
Data Transferred (Sent/Received) [MB/MB]: 40.00 / 100.57
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 22.5 / 43.0
SN Margin (Up/Down) [dB]: 6.5 / 2.0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Error Seconds (Local/Remote): 32 / 0
FEC Errors (Up/Down): 42 / 1,113,054
CRC Errors (Up/Down): 42 / 1,525
HEC Errors (Up/Down): 30,553 / 555
Yep disconnect back up now reconnected at a lower speed:
DSL Connection
Link Information
Uptime: 0 days, 0:00:41
Bandwidth (Up/Down) [kbps/kbps]: 1,235 / 7,656
Data Transferred (Sent/Received) [KB/KB]: 40.00 / 23.00
SN Margin (Up/Down) [dB]: 7.0 / 6.0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 42 / 0
FEC Errors (Up/Down): 0 / 67
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 30,608 / 0
