- 30 Jul 2006
What are the comparative advantages and disadvantages of 16", 17" and 18" wheels?
Sorry I am lost here, what do you mean by profile? Is this the area in contact with the road?The larger the wheel, the smaller the profile of the tyre. This leads to less tyre-wall flex and tighter handling. The downside is that the ride will be more harsh.
I am thinking of buying a Skoda Octavia SE Estate. Major concern is stability on snow and ice (French Alps).It can depend on the specific wheels, but smaller wheels are generally lighter and tyres are cheaper.
What car are you thinking of changing sizes on and what will you use it for?
[TW]Fox;24941331 said:For normal road use with no performance requirements larger wheels reduce ride quality and generally increase tyre price but look better.
How so? Even if they are lighter, they aren't really going to have any significant impact on inertia?Smaller wheels also afford a greater rate of acceleration.
The smaller the wheel, the smaller the penis.
Dont they loewer top speed tho? (i realise unless a car is waaaaaaaaaaaaay underpowered this wont make any difference).
