Just pulled out this machine after scratching my head a few years ago. I'll try provide as much info as possible, if I've missed anything please ask. I want to know what the hell this is as 'Advent' hasn't got support, well it has but it hasn't got an official driver, info site. I'm not after driver as such as driver genius can help with that. I am although after a BIOs update if there is one. Also want to know if the mobo can take powerful RAM (current has 4 slots with 3 256 and 1 512 mb sticks in I think) and a CPU upgrade.
The system fascinates me for some reason, may mod it up a bit but am completely dumbfounded at the moment to what the hell this is, where the info is, BIOs update, what RAM it can take (if it can take more powerful RAM).. a better processor etc..
as always your help is much appreciated.
found a bit info here but need to double check before doing anything...
Code:
[URL="http://www.uktsupport.co.uk/advent/pc/3216.htm"]http://www.uktsupport.co.uk/advent/pc/3216.htm[/URL]
--------[ AIDA64 Extreme Edition ]--------------------------------------------------------------------------------------
Version AIDA64 v2.00.1700
Benchmark Module 2.7.391-x32
Homepage http://www.aida64.com/
Report Type Report Wizard
Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP RTM)
Date 2011-12-27
Time 16:20
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
Computer Type ACPI Multiprocessor PC
OS Service Pack Service Pack 3
Internet Explorer 8.0.6001.18702 (IE 8.0)
DirectX 4.09.00.0904 (DirectX 9.0c
Motherboard:
CPU Type Intel Pentium 4, 2800 MHz (14 x 200)
Motherboard Name TriGem Advent Series
Motherboard Chipset Intel Springdale i865PE
System Memory 1280 MB (PC2100 DDR SDRAM)
DIMM1: Samsung M3 68L6423DTL-CB0 512 MB PC2100 DDR SDRAM (2.5-3-3-6 @ 133 MHz) (2.0-2-2-5 @ 100 MHz)
DIMM2: Samsung M3 68L3223ETN-CB0 256 MB PC2100 DDR SDRAM (2.5-3-3-6 @ 133 MHz) (2.0-2-2-5 @ 100 MHz)
DIMM3: Samsung M3 68L3223ETN-CB0 256 MB PC2100 DDR SDRAM (2.5-3-3-6 @ 133 MHz) (2.0-2-2-5 @ 100 MHz)
DIMM4: Samsung M3 68L3223ETN-CB0 256 MB PC2100 DDR SDRAM (2.5-3-3-6 @ 133 MHz) (2.0-2-2-5 @ 100 MHz)
BIOS Type Award (05/06/03)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter NVIDIA GeForce4 MX 440 (128 MB)
3D Accelerator nVIDIA GeForce4 MX 440
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Vendor Phoenix Technologies, LTD
Version 6.00 PG
Release Date 05/06/2003
Size 256 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Supported Standards DMI, APM, ACPI, ESCD, PnP
Expansion Capabilities ISA, PCI, AGP, USB
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/pages/products
BIOS Upgrades http://www.aida64.com/bios-updates
[ System ]
System Properties:
Manufacturer TriGem Computer NETHERLANDS
Product Advent Series
Version Ver1.0
[ Motherboard ]
Motherboard Properties:
Version Ver1.0
[ Memory Controller ]
Memory Controller Properties:
Error Detection Method 8-bit Parity
Error Correction None
Supported Memory Interleave 1-Way
Current Memory Interleave 1-Way
Supported Memory Voltages 5V
Maximum Memory Module Size 1024 MB
Memory Slots 4
[ Processors / Intel Pentium(R) 4 ]
Processor Properties:
Manufacturer Intel
Version Intel Pentium(R) 4
External Clock 200 MHz
Maximum Clock 3066 MHz
Current Clock 2800 MHz
Type Central Processor
Voltage 1.4 V
Status Enabled
Upgrade ZIF
Socket Designation Socket 478
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://ark.intel.com/search.aspx?q=Intel Pentium 4
Driver Update http://www.aida64.com/driver-updates
[ Caches / Internal Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 20 KB
Installed Size 20 KB
Supported SRAM Type Synchronous
Current SRAM Type Synchronous
Socket Designation Internal Cache
[ Caches / External Cache ]
Cache Properties:
Type External
Status Enabled
Maximum Size 512 KB
Installed Size 512 KB
Socket Designation External Cache
[ Memory Modules / A0 ]
Memory Module Properties:
Socket Designation A0
Installed Size 512 MB
Enabled Size 512 MB
[ Memory Modules / A1 ]
Socket Designation A1
Installed Size 256 MB
Enabled Size 256 MB
[ Memory Modules / A2 ]
Socket Designation A2
Enabled Size 256 MB
[ Memory Modules / A3 ]
Socket Designation A3
Enabled Size 256 MB
[ Memory Devices / A0 ]
Memory Device Properties:
Form Factor DIMM
Type SDRAM
Type Detail Synchronous
Size 512 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A0
Bank Locator Bank0/1
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
[ Memory Devices / A1 ]
Form Factor DIMM
Type SDRAM
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A1
Bank Locator Bank2/3
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
[ Memory Devices / A2 ]
Form Factor DIMM
Type SDRAM
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A2
Bank Locator Bank4/5
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
[ Memory Devices / A3 ]
Form Factor DIMM
Type SDRAM
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A3
Bank Locator Bank6/7
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Northwood HyperThreading
CPU Stepping D1
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 2.80GHz
CPUID Revision 00000F29h
CPU Speed:
CPU Clock 2800.4 MHz (original: 2800 MHz)
CPU Multiplier 14x
CPU FSB 200.0 MHz (original: 200 MHz)
Memory Bus 133.4 MHz
DRAM:FSB Ratio 4:6
CPU Cache:
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard ID 05/06/2003-Springdale-G-6A79AM4AC-00
Chipset Properties:
Memory Timings 2.5-2-4-5 (CL-RCD-RP-RAS)
PAT Disabled
BIOS Properties:
System BIOS Date 05/06/03
Video BIOS Date 04/25/03
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message 1.00 (DX)
DMI BIOS Version 6.00 PG
Graphics Processor Properties:
Video Adapter Asus V8170 DDR SE/128
GPU Code Name NV17 (AGP 4x 10DE / 0171, Rev A5)
GPU Clock 250 MHz
Memory Clock 166 MHz
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type Winbond W83627HF (ISA 290h)
Chassis Intrusion Detected No
Temperatures:
Motherboard 22 °C (72 °F)
CPU 38 °C (100 °F)
ST3160021A 31 °C (88 °F)
Cooling Fans:
CPU 3924 RPM
Chassis 2557 RPM
Voltage Values:
CPU Core 1.472 V
Aux 1.552 V
+3.3 V 3.424 V
+5 V 5.107 V
+12 V 12.221 V
-12 V -12.363 V
-5 V -5.351 V
+5 V Standby 5.042 V
VBAT Battery 3.008 V
Debug Info F 2B 42 FF
Debug Info T 22 38 127
Debug Info V 5C 61 D6 BE C9 1F 2F (01)
Debug Info I 21 523A
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Stepping D1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 2800 MHz
Min / Max CPU Multiplier 14x / 14x
L1 Data Cache 8 KB
Multi CPU:
CPU #1 Intel(R) Pentium(R) 4 CPU 2.80GHz, 2800 MHz
CPU #2 Intel(R) Pentium(R) 4 CPU 2.80GHz, 2800 MHz
CPU Physical Info:
Package Type 478 Pin FC-PGA2
Package Size 35 mm x 35 mm
Transistors 55 million
Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
Die Size 131 mm2
Core Voltage 1.475 - 1.55 V
I/O Voltage 1.475 - 1.55 V
Typical Power 38.7 - 89.0 W (depending on clock speed)
Maximum Power 49 - 109 W (depending on clock speed)
CPU Manufacturer:
CPU Utilization:
CPU #1 / HTT Unit #1 0 %
CPU #1 / HTT Unit #2 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
IA Brand ID 09h (Intel Pentium 4)
Platform ID 1Fh / MC 04h (Socket 478)
Microcode Update Revision 2E
HTT / CMP Units 2 / 0
Instruction Set:
64-bit x86 Extension (AMD64, Intel64) Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD 3DNowPrefetch Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
AMD FMA4 Not Supported
AMD MisAligned SSE Not Supported
AMD SSE4A Not Supported
AMD XOP Not Supported
Cyrix Extended MMX Not Supported
Enhanced REP MOVSB/STOSB Not Supported
Float-16 Conversion Instructions Not Supported
IA-64 Not Supported
IA BMI1 Not Supported
IA BMI2 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE2 Supported
IA SSE3 Not Supported
IA Supplemental SSE3 Not Supported
IA SSE4.1 Not Supported
IA SSE4.2 Not Supported
IA AVX Not Supported
IA AVX2 Not Supported
IA FMA Not Supported
IA AES Extensions Not Supported
VIA Alternate Instruction Set Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
INVPCID Instruction Not Supported
LZCNT Instruction Not Supported
MONITOR / MWAIT Instruction Not Supported
MOVBE Instruction Not Supported
PCLMULQDQ Instruction Not Supported
POPCNT Instruction Not Supported
RDFSBASE / RDGSBASE / WRFSBASE / WRGSBASE InstructionNot Supported
RDRAND Instruction Not Supported
RDTSCP Instruction Not Supported
SKINIT / STGI Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
Trailing Bit Manipulation Instructions Not Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Advanced Cryptography Engine 2 (ACE2) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Hardware Random Number Generator 2 (RNG2) Not Supported
PadLock Hash Engine (PHE) Not Supported
PadLock Hash Engine 2 (PHE2) Not Supported
PadLock Montgomery Multiplier (PMM) Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Application Power Management (APM) Not Supported
Automatic Clock Control Supported
Core C6 State (CC6) Not Supported
Digital Thermometer Not Supported
Dynamic FSB Frequency Switching Not Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
Hardware P-State Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
Overstress Not Supported
Package C6 State (PC6) Not Supported
Parallax Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Not Supported
Thermal Monitor 3 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
1 GB Page Size Not Supported
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
Core Performance Boost (CPB) Not Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Supported
Debugging Extension Supported
Direct Cache Access Not Supported
Dynamic Acceleration Technology (IDA) Not Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Supported, Enabled
Instruction Based Sampling Not Supported
Invariant Time Stamp Counter Not Supported
L1 Context ID Supported
Lightweight Profiling Not Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Nested Paging Not Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Supported
Physical Address Extension (PAE) Supported
Safer Mode Extensions (SMX) Not Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Supervisor Mode Execution Protection (SMEP) Not Supported
Time Stamp Counter (TSC) Supported
Turbo Boost Not Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
Watchdog Timer Not Supported
x2APIC Not Supported
XGETBV / XSETBV OS Enabled Not Supported
XSAVE / XRSTOR / XSETBV / XGETBV Extended States Not Supported
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 4:6
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 1279 MB
Used 967 MB
Free 312 MB
Utilization 76 %
Swap Space:
Total 3053 MB
Used 976 MB
Free 2077 MB
Utilization 32 %
Virtual Memory:
Total 4333 MB
Used 1943 MB
Free 2390 MB
Utilization 45 %
Paging File:
Paging File C:\pagefile.sys
Initial / Maximum Size 1920 MB / 3840 MB
Current Size 1920 MB
Current / Peak Usage 145 MB / 150 MB
Utilization 8 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Samsung M3 68L6423DTL-CB0 ]
Module Name Samsung M3 68L6423DTL-CB0
Serial Number 030C559Fh (2673150979)
Manufacture Date Week 37 / 2003
Module Size 512 MB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC2100 (133 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 133 MHz 2.5-3-3-6 (CL-RCD-RP-RAS)
@ 100 MHz 2.0-2-2-5 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Memory Module Manufacturer:
Company Name Samsung
Product Information http://www.samsung.com/global/business/semiconductor
[ DIMM2: Samsung M3 68L3223ETN-CB0 ]
Module Name Samsung M3 68L3223ETN-CB0
Serial Number 060D8EA4h (2760772870)
Module Size 256 MB (1 rank, 4 banks)
Module Width 64 bit
Memory Timings:
@ 133 MHz 2.5-3-3-6 (CL-RCD-RP-RAS) / 9-10-2 (RC-RFC-RRD)
@ 100 MHz 2.0-2-2-5 (CL-RCD-RP-RAS) / 7-8-2 (RC-RFC-RRD)
[ DIMM3: Samsung M3 68L3223ETN-CB0 ]
Serial Number 060294A2h (2727608838)
Module Width 64 bit
Memory Timings:
[ DIMM4: Samsung M3 68L3223ETN-CB0 ]
Serial Number 060B8EF2h (4069395206)
Module Width 64 bit
Memory Timings:
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Springdale i865PE ]
North Bridge Properties:
North Bridge Intel Springdale i865PE
Supported FSB Speeds FSB400, FSB533, FSB800
Supported Memory Types DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM
Maximum Memory Amount 4 GB
Revision / Stepping 02 / A2
Package Type 932 Pin FC-BGA
Package Size 37.5 mm x 37.5 mm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
PAT Disabled
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 2T
RAS Precharge (tRP) 4T
RAS Active Time (tRAS) 5T
Refresh Period (tREF) 7.8 us
Error Correction:
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 512 MB (PC2100 DDR SDRAM)
DRAM Slot #2 256 MB (PC2100 DDR SDRAM)
DRAM Slot #3 256 MB (PC2100 DDR SDRAM)
DRAM Slot #4 256 MB (PC2100 DDR SDRAM)
AGP Controller:
AGP Version 3.00
AGP Status Enabled
AGP Device Asus V8170 DDR SE/128
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x, 4x, 8x
Current AGP Speed 4x
Fast-Write Supported, Enabled
Side Band Addressing Supported, Disabled
Chipset Manufacturer:
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets
[ South Bridge: Intel 82801EB ICH5 ]
South Bridge Properties:
South Bridge Intel 82801EB ICH5
Revision / Stepping C2 / A2/A3
Package Type 460 Pin mBGA
Package Size 31 mm x 31 mm
Process Technology 180 nm
Core Voltage 1.5 V
TDP 2.4 W
AC'97 Audio Controller:
Audio Controller Type Intel ICH5
Codec Name C-Media I9739(A)
Codec ID 434D4961h
S/PDIF Output Supported
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
BIOS Version 1.00 (DX)
BIOS Manufacturer:
