Advent 5411
Caporegime
3 Jan 2006
Chadderton, Oldham
Is the above laptop worth it? I can get it for 429 quid, specs are:
CPU Intel Core 2 Duo T5750 (2.0GHz)
BIOS Phoenix BIOS. Press F2 to enter
Chipset Intel G965 Express
Memory 4GB DDR2 667MHz (2x 2GB) *
Hard Drive 320GB SATA
CD Drive DVD±RW
Screen 15.4" TFT WXGA (1280x800)
Video Card Integrated Intel G965 Express (up to 358MB)
Webcam Built in
Sound Card Realtek High Definition Audio
Modem 56k
Network Card Realtek 8169/8168/8101 PCI/PCIe
Intel Pro 3945ABG wireless LAN
Bluetooth by Toshiba
Ports 1x Headphone
1x Microphone
1x HDMI
1x LAN
3x USB
1x ExpressCard
1x Card Reader
1x Modem
1x Kensington Lock
1x VGA
Its not for gaming really as I got my main rig but would it be able to play GTA SA or UT2004?
Thanks
Will.
My gut reaction is that UT probably ok, but not sure on GTA......integrated gfx is rarely up to much :(
...unless you drop the res a little ?
Maybe, I notice my friends bro's celeron laptop plays it on high 800x600 but runs at about 20fps.
I don't need games on it really but it would be nice to play abit of UT2004 or something on short breaks :p
Also would it be possible to overclock the CPU in it? As long as temps aint like over 70 degrees load?
The BIOSes of laptops are usually locked down so unless you find a modded BIOS there's nothing really you can do.
