Hello all
I'm reformatting an Advent 7088 for a friend, and all is dandy apart from it will not connect to my wireless network at all.
Its running a fresh install of XP SP2, and has a Realtek Ralink 8139 wireless card in it. I found and installed the 3.0.1.0 driver from Realtek, and it will bring my network up in the "site survey" window. However, the "connect" box is disabled, and I can't get on with the windows configuration either.
The wired LAN works fine on the same network - using it now.
Can anyone shed some light on it? The router is a Netgear DG834GT, other PC's connecting wirelessly fine.
HELP!
Thank you all.
HELP!
Thank you all.
