Advent 9115 fault
25 Jan 2009
Help, Got an advent laptop, do'nt use it much, Tried switching on last night and won't even put the power light on, had it on charge overnight and still no power light comming on. Is the a reset button or a fuse inside, tried looking on Google and can't find much on it. Thanks
you can try taking the battery and charger out and then holding the on button for a few seconds, put it all back in and try again, do you get a charge light at all, do you have a multimeter to check the psu has out put?
Used to have one of these, sounds like its the power supply to be honest, will never have another Advent laptop again.
If you've tried taking the battery out and just plugged the power supply in then I'd see about getting a new supply (£40 ish I think)
