Advice 27" for editing
20 Nov 2020
Hello,
I am buying my first monitor I have a budget of max €400 (that I can stretch a little bit).
I will use the monitor for photo and video editing, productivity and very occasional gaming.
I am looking for a 27 inches with resolution: 2560 x 1440.
Other Features min. 8 bits, sRGB >99%, Adobe RGB >70%
I have done some research and I found this two: https://www.displayspecifications.com/en/comparison/c5f838f81
  • BenQ PD2700Q, I have found it at €323
  • ViewSonic VP2768, I have found it at €414
I need help deciding between this two monitors or if there are any better one?
The specs looks similar but there is €100 difference... I have read good stuff about ViewSonic, Is BenQ reliable brand?
Thanks to all
