Advice - 3 pin XTX power connector
15 Feb 2024
UK
Hey folks,
I'm looking at this card:
It's got 3x 8 pin power connectors but can I get away with just two and the draw from the PCI Express socket? I plane on undervolting this too btw
Thanks
7 Dec 2010
Leeds
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
The Corsair VS series are garbage with cheap and nasty internals, are only basic 80+ white certified and should be avoided. Never skimp on the psu. Buy cheap, buy twice has never been more true than when buying a psu. The stock 7900XTX will draw up to 360w by itself when gaming with spikes up to 460w and that's just the graphics card. You are looking at a overclocked card that will have a even higher power draw. Asrock recommends a 1000w psu for that card although that seems rather excessive and I would say a decent quality 850w minimum although for the small price difference between a decent 850w and a decent 1000w you may as well go for the 1000w for future proofing and make sure it's ATX 3.0 as well.
