Advice about graphics card capability
Permabanned
20 Feb 2006
Edinburgh
Would a X1800XT 512mb (along side a Opty 146 @ 3ghz) be good enough to use with a Belinea 2225S1W 22" Widescreen LCD Monitor to play the following games at native res ? :
Splinter cell double agent
Need for speed carbon
Counter strike source
i've moved this to graphics card forum for you as i think it's more of a question about what your graphics card can manage. To clarify, the OP is asking if his set up and GFX can potentially support a 1680 x 1050 resolution for gaming?
(note: left a referral from monitors forum in case anyone can help from there too :))
Depends on how high you like your frame rates. But it won't be unplayable if that's what your asking. I know oblivion runs quite well on the 256mb version at that res.
I dont know about the other two but css will be fine, i ran it on an X800, max settings on a 19"ws.
Aslong as you don't go overboard (i.e. 16x AF and 8x AA would be a no no) with the quality settings you should be able to play those games fine...
Thanks for the help guys and cheers for moving this thread ;)
I like to have 60+ frames per second unless its need for speed as racing games seem to be smooth at 40+.
