That mobo i've chosen says it supports 2133 ram (OC). Does that mean the ram you suggested will work or will it need overclocking? I'm still learning all this computer stuff so help is appreciated thanks .
It will work just set the bios XMP profile to 2133mhz. but Apparently this RAM can get a little hot. If it does just set the speed back to stock. Job done.
