Permabanned
- 15 Nov 2008
Hi guys, Ive not WC before and am thinking of getting a system
Firstly Id be buying a MM UFO case to house, Id also like to look at 2 loops, one for gfx one for CPU
Now main bit of advice Im after first is on the rads, the standard panels on the UFO support a 120.3 and 120.2, so if I went with the standards then would the 120.2 be sufficient to cool CPU? and would a 120.3 be sufficient to cool a dual gfx card set up?
Thanks in advance
Thanks in advance
