Advice appreciated
3 Jan 2012
Hi,
First off I think I should clarify that when it comes to hardware im a bit of a noob so any advice would be great :D
Im after a tower designed for gaming (WoW, COD, BF etc) and downloading and playing movies, my budget is £500 give or take a little.
Is there a prebuilt system out there for me or am I best off getting a custom built.
Thanks in advance!
Hi and welcome to forums
This would be a good build for your uses, given your edit I changed the normal HDD to a SSD as it will be much faster and you can use your external drive for storage, though you will be limited on space, you could swap it back if you prefer
This uses an Intel based system and has good room for future upgrades, it has very good case and excellent PSU to support bigger gfx in future, by buying both Antec, if you use the code AG15 during checkout you get 15% off the case&PSU price, this brings you in under £500, the mobo will support the addition of an i5 2500K CPU at a later time, though depending on how flexible your budget is you may be able to squeeze one in now, though I wouldnt do this at the expense of your gfx option
YOUR BASKET
1 x OcUK ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card £113.99
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £91.19
1 x Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) £87.98
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £81.38
1 x Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply £69.98
1 x Antec 100 One Hundred Ultimate Gaming Case - Black £46.99
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £17.99
1 x LG GH22NS70 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £539.50 (includes shipping : £12.50).
95thrifles specs look good to me, and like he said if you can afford that little bit extra the i5 2500k would be a very nice addition and probably last a little longer before you need to upgrade again, also if not known there is now a 2GB version of the 6850 which was released late November by Sapphire that can be had for not much more money.
BTW 95thrifles took me awhile to read your post due to the distraction of your lovely sig!!! :)
Thanks for the speedy response!
95thrifles - WoW will be the game that will be played mainly on it for the foreseeable future, would that build play it on high settings whilst maintaining a high FPS?
Also could you post a link for the i5 2500K CPU you mentioned, I searched for it on the OCUK shop but im unsure as to what im looking for :p
Thanks again.
Like I said before, when it comes to computer hardware I haven't a clue, don't get me wrong im not saying im useless with pc's ive just never needed to know... so no ive never built a pc.
My intention was to see what you guys thought would be best for my needs (as i have heard this is the place to go for quality advice) order all the parts off OCUK and pay my local computer shop to build it for me.
Why not take the leap and build it yourself?
It's actually not that hard, there are several videos around explaining it step by step. It also gives a feeling of satisfaction that you have put it all together yourself :)
Don’t be put off on building your first pc, anything your unsure about just drop a post on here has there are loads of experienced guys\gals that will give you advice. You will get great satisfaction from building your first rig and probably never buy another off the self one again. One thing you will have to watch out for is the “upgrade bug” because once you catch it, it will almost kill your wallet\credit card. ;)
Link to system build guide;
http://forums.overclockers.co.uk/showthread.php?t=18046396
UNDERSTATEMENT My girlfriend hates this PC.
Anyways have a look at "ThenewBoston" or similar on youtube as he did some very good buld tutorials which helped build my confidence.
