- 22 Jul 2010
- Kent
I'm looking for a lil advice. I'm interested in purchasing this board and coupling it with the phenom II X2 555 BE. I am however unsure of compatibility.
The asus website states that it does support the cpu but only from bios 0506 (earliest bios is 0303 i believe) and pcb revision it states any.
Does this mean that the board will post with the cpu installed (on any pcb) and then i must flash the bios to gain full support for the CPU? Or will i have to try and find a cheaper supported cpu for the bios that is installed on the board, update bios and then fit the 555be cpu?
Any thoughts or if anyone has this board and has had cpu's post that are not officially supported on the boards supplied bios....i'd love to hear from you. Thanks in advance
