Advice buying ram
28 Jun 2013
Hi so I'm pretty new to building pc's so apologies for this noob question. Anyways Ive got a system with 16gb Team Group Vulcan T-Force 2x8GB DDR4 3200MHz memory and looking to buy another 2x8 to bump the system up to 32. My motherboard is Asus Prime Z390M-Plus. My question is do i have to buy the same exact memory manufacturer ram for it to be compatible with my system or am i okay with going with a different brand as long as the parameters are the same? For example i found this, would that be okay? *HyperX HX432C16PB3K2/16 Predator DDR4 16 GB (Kit 2 x 8 GB), 3200 MHz CL16 DIMM XMP *. Would that even work or do i need to buy 2x16gb?
Thank you all for answers!
Any similar clock speed/latency memory is good.
Even if buying precisely same model number memory those might come with different DRAM chips now.
