Evening all
After an 8 year break from PC gaming, I'm ready to jump back in. I've recently been having an urge to finally build my own PC, but with no experience, I'm looking to yourselves for some advice!
1. I guess my first question is whether it's worth it? My budget is £800 and I'd obviously like to run all the latest games with good graphics. Is that possible? What resolution, texture quality would I expect to use for a game like BF4?
NOTE: BUDGET IS ONLY FOR THE PC. I DON'T NEED WINDOWS, A KEYBOARD, MOUSE, OR MONITOR.
2. Does the motherboard directly effect performance? I know it obviously determines what hardware I can use, but if I had a cheap 1155 motherboard compared to a mid-range one. Would the same CPU run better on the mid-range motherboard? - Hopefully that makes sense!
3. Intel v AMD? I know this will no doubt start a bit of a war, but I've heard you get more bang for your buck with AMD, but Intel is much better for gaming.
4. SATA v SSD? I reguarly see people suggesting to buy a small SSD to compliment a SATA HD. You then install the OS and common games on the SSD to improve boot times. Although the games will load quicker, does it actually improve the performance?
SSD is still quite expensive, and as I'm on a budget, I think this might be where I save some money by only buying a SATA HD.
5. Memory? I often see people saying that you only need a maximum of 8GB of RAM for gaming. Is this true? Would having 16GB not make any difference?
I think that's all the questions I have for the moment.
Thanks in advance for any help you provide!
