Hi,
My old 2015 overclockers pre-built is showing its age (i5 and GTX-970) and for once I am going big instead of going for the best value (as I have always done before).
The new build will be only for gaming on a 4k OLED TV (which I think has a 60 fps maximum, right?). It will live beside the TV in the living room, so I would like it to be quiet.
Here's what I'm thinking so far:
- CPU - For gaming only, am I correct that the i7-9700K is the sweet spot?
- Cooler - I am gun-shy about water cooling so would something like a Dark Rock Pro 4 work?
- Ram - 16GB, I think. Does speed matter? (No RGB, ideally)
- GPU - 2080ti - which one do you recommend? Is it worth spending more on a better one?
- SSD - at 1TB, is there money to be saved by using a sata SSD instead of an NVMe?
- Power Supply - How much power do I need? 650W? 750W?
- Motherboard - no particular requirements, any recommendation welcome (I don't need WiFi)
- Case - I'd like something inconspicuous (and ideally not huge) and I am anti-rgb and would avoid a glass-panelled case
I have built a PC myself before, but last time I got the good folks at overclockers to build it and I think I'll do the same this time, just for peace of mind.
So this is my one shot at going all out on a PC. Help me to go mad!
Thanks.
Thanks.
