Hi,
I'm looking at purchasing a set of hi-fi headphones, but I have very little experience/knowledge with good ones. I'm looking to spend no more than £50, although I could be pushed a little for the right product...
A friend of mine has the Sony MDR-7506, which are about twice my budget, but that's my current "reference" for "good headphones" - something with somewhat "similar" sound and build quality would be nice.
I'd appreciate a quick rundown on the different things I should be looking for e.g. impedance (is high or low better, and why?), closed/open/semi-open back (advantages/disadvantages of each?), Sound Pressure Level, Total Harmonic Distortion...
Thanks very much.
Regards, Dominic
Thanks very much.
Regards, Dominic
