Hi guys
I'm new to watercooling and planning a build in my Fractal Define C (atx not m-atx) version when Zen2 is released sometime this summer. I've read a lot of threads and watched a lot of guides so my current plan is:
Green is for pump / res positions
Most watercooling builds with the Define C I've seen have the pump / res attached vertically underneath the front radiator where there is a removable drive cage, however mine is filled with drives so I can't do that. So heres what I'm thinking:
https://www.overclockers.co.uk/bitspower-z-multi-100mm-water-tank-wc-317-bp.html
https://www.overclockers.co.uk/xspc-d5-vario-with-front-cover-1-2-barbs-sata-power-wc-43j-xs.html
Cheers for any help you can give, or troubles I might have missed.
Edit
I should stress the height between the GPU & shroud is only 90mm & probably less than 150mm in height to attach a res to the front rad
- Hard line tubing, 14mm thick
- 280mm rad (front) & 240mm rad (top)
- CPU & GPU full cover blocks (already have)
- Have a small pump res combo attached to the top front radiator, but will that get in the way of tubing between the rads or the ram.
- Have a horizontal pump res combo beneath the graphics card, but will that get in the way of tubing to the card itself and how would I drain that with a horizontal res
- Have a separate pump and res, with the pump below the GPU just to the left of the bottom rad and the reservoir attached above it to the radiator with connecting tubing.
Edit
I've got all the components now bar fittings and tubing. Going for a Hardline build. Just have to work out how to attach the resovoir to the radiator. Waiting for my new Zen build and then I'll be doing it
