Hi
I'm in need of some advice, I was brought a game for Christmas but my computer comes up with a error regarding shader model 3 when i try to open it. Ive tried updating drivers but intel updater informs me the drivers are upto date but when i use opengl to check the specs its not updated.
My computer is a Parkard bell imedia s3800 and has an Intel core I3 CPU 530 @ 2.93Ghz
It says it has Intel HD graphic. I have taken the side of the unit off and found that its built in graphics card.
My question is would it be worth buying a dedicated graphics card (the Game requires ATI RADEON HD2600/NVIDIA GEFORCE 8600 or better). And could you recommend a new card? not looking for anything fancy as im not a serious gamer.
i think my power supply will need changing as well as its only 250w.
Really its just a cheap fix to play a game as the computer is only used now for itunes and sorting pictures.
any help would be great thanks
