Advice for AGP 3850 users to avoid problems
29 Jan 2007
Introduction
First of all, I love this card. For the first time, AGP users are not paying a huge premium for a cut down card, so I couldn't resist one last purchase for my aging system (2.4Ghz Venice Athlon64). I don't play many PC games since making the transition to the PS3. PC exclusives are now a thing of the past so I've never required the power of dual core solutions for general PC use. I still keep an eye on the market however and fancied COD4 on the PC so I can enjoy the keyboard and mouse. This card runs cool and finally makes shader/HD games smooth, even on a single core processor. Very impressed.
After reading around the net, I noticed some people have problems with these awesome cards regardless of the vendor (overclockers are currently selling the Sapphire model) and I thought I'd share my experiences.
I bought the Club3D/Powercolor version of the card as I like the heatsink design much better - far easier to clean and better quality. I also only had a 6 pin PCI-E connector on my Akasa 460W PSU, while the Sapphire model requires the 8-pin (lucky I noticed this before deciding which to buy!).
On arrival of the box, it appears to be missing a molex->PCI-E adaptor and a composite to composite lead according to the reviews. Very good job my PSU had the 6 pin connector, or I would have been stuck. The box also wasn't sealed and looked like it had been opened previously (IT'S NOT OVERCLOCKERS UK WHO SENT ME THE CARD BTW). Can anyone confirm the extras that came with your cards (sapphire/club3d/powercolor)?
I can't be bothered to send it back for such minor things, but are such practices (open boxes getting sent out as new) common practice among e-tailors? I'd imagine it happens when stuff is sent back immediately as faulty, but then tested as fine so goes back on sale. Shouldn't these be sold as refurbished?
Advice
  • The card froze in 3D applications and at first I considered the PSU. However, after reading around the net, many fell into the trap of buying new PSU's only to find it wasn't the problem. Others disable fast writes and reduce the AGP speed from 8x to 4x. For me, that was not the problem. The issue was a simple bios setting - DBI output for AGP transfer. Once I disabled that, everything worked 100%. This setting simply tries to communicate with the AGP card differently to save power and reduce interference, nothing to do with performance, but perhaps it doesn't work right with the bridge chip and my K8T800pro chipset.
  • With the default drivers provided (cat 8.4), certain bold links on webpages come up as red when they should be blue. A strange minor problem, but annoying. There is a hotfix available from the AMD/ATI site that should fix the issue according to the net. Perhaps the latest catalysts do, but I haven't tried yet. Apparently ATI/AMD still don't directly support the AGP version of the card so you have to add the device ID manually to the drivers if you want to use newer ones than provided on the packaged CD.
The link to the official hotfix is here:
http://support.ati.com/ics/support/KBAnswer.asp?questionID=31625
Ok, I hope this helps some of you.
