Hi All,
I’ve always been a bit in the dark when it comes to audio setups, I’ve never quite understood how it works and so have never had anything more than monitor audio or standard audio jack headphones.
I’m planning a new setup which will include dual monitors (possibly tri monitors) running a PC and PS4. I would like to have an audio set up that will offer a bit more quality than the monitors. Im not looking for anything amazing or massively expensive, just something than I can run both the PC and PS4 through (ideally without having to manually switch cables etc).
As a bonus, I may also mount a TV on the wall which would be great if I could also run through the same setup.
Thanks in advance!
Thanks in advance!
