Advice for budget gaming PC
10 Apr 2015
Hungerford, UK, Earth
Hi, have been asked to build a budget gaming pc for a mate, Box only , budget is around the £650 mark including windows. I have put a hastily put together haswell build in below. gaming will be at 1080p, wont be going for very high detail. I'm open to skylake or going i3 and AMD Gpus are an option
Ive warned him that new GPUs could be coming in June, but he needs the build sooner
any suggestions or comments welcome
My basket at Overclockers UK:
Total: £645.45
(includes shipping: £11.70)
The I3 is no slouch and performs very well at 1080p with a mid range gpu. I would probably get a cheaper case and get 16gb of ram.
yeah I just picked the case randomly.. just needed some feedback.. which is good, I will push towards the i3 unless I hear different and play with the 16gb option.
he also needs to decide if he is going to build it himself with my help, or get ocuk to do it, which I guess is another £50 ish..
