I started looking at buying an Antec Fusion and building an HTPC myself, then saw the "Verso" AMD Athlon 64 X2 4200 Dual Core 2.2GHz DDR2 HTPC System - Black which I think is a bargain at £349 exVAT and uses precisely that case.
Now, for you 'stock gurus' out there what I simply dont have is knowledge of the alternatives and whether I might still be better off price-wise with a different combination of hardware to put into the Case, rather than the ready made OCuk option.
My main area of ignorance is how good/bad are the integrated graphics of the mobo are. My main function will not be gaming, but it would be welcome if theres a better graphics option at a similar price. Same goes for the memory included.
Any suggestions? Maybe I should go for a totally different case I am unaware of?
