Hi,
In my PC currently this is the airflow system I have:
I have checked HWMonitor and my computer isn't overheating at all, it sits around 40 and when heavily gaming goes to around 70. What I have noticed is when I touch the perspect plastic window it becomes really hot because of the GPU and the PSU powers on for a few seconds which I assume is exhausting out hot air. So I was thinking about buying a couple more fans for my PC to help reduce the heat generated inside the case.
My questions are:
1) Should I buy fans or will they be a waste at the moment
2) Where should I mount my fans, on the top (pulling or pushing air) or one on the front (I have one there already).
3) Which fans do you recommend
I have had a look and I wanted to keep a nice black/blue theme and I saw these:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-042-AE&groupid=701&catid=2331
http://www.overclockers.co.uk/showproduct.php?prodid=FG-015-CS
Thanks and all help is appreciated,
My questions are:
Does it make a big difference. I mean I understand its pulling hot air into it and out the back but having it the other way surely its just pulling cold in air and putting it back out, its not getting anything into the case?
