Hello all.
I'm looking to build my first PC. I'm not a gamer. I play the odd free MMORPG or strategy game but rarely. I'm not going to be getting a graphics card. At least not anytime soon. I mainly watch tv on my computer, stream a lot of videos and use the internet a lot (lots of tabs open at once, lots of bookmarks/favourites, etc) and my current computer is starting to struggle. So I want a fast PC with good quality display, no video card. My budget's around £600 - £700 (including a new monitor). But I do want this PC to be noticeably good and last a long time, with the possibility of upgrading it in the future, even if with just a new mobo and CPU and more RAM.
I've narrowed the case down to one of these two. I prefer the cheaper one purely because of the black back and interior, but I'm wondering why the other costs more? Is there a feature I'm overlooking?
- http://www.overclockers.co.uk/showproduct.php?prodid=CA-573-LL
- http://www.overclockers.co.uk/showproduct.php?prodid=CA-371-LL
The monitors are all pretty similar. I'm leaning towards a more expensive one because it has a HDMI port which I imagine is better quality than VGA or DVI, and more compatible with more things. I was thinking something like this?
- http://www.overclockers.co.uk/showproduct.php?prodid=MO-097-IY&groupid=17&catid=510
- http://www.overclockers.co.uk/showproduct.php?prodid=MO-081-BQ&groupid=17&catid=510
I've half filled my current 500GB Seagate Barracuda HD so my choices when it comes to a hard drive are either, a 250GB SSD and hope I can manage. Or, preferably, a 128GB SSD with an additional HD. I'm not sure how to set that up but I'm sure I can find out. I'm leaning towards the 128GB SSD because of how much cheaper it is. And I would probably use my current HD rather than buy a new one. What's the difference between these first two and last three? Anyway, the ones I've considered are:
- http://www.overclockers.co.uk/showproduct.php?prodid=HD-158-SA&groupid=701&catid=2104
- http://www.overclockers.co.uk/showproduct.php?prodid=HD-161-SA&groupid=701&catid=2104
- http://www.overclockers.co.uk/showproduct.php?prodid=HD-159-SA&groupid=701&catid=2104
- http://www.overclockers.co.uk/showproduct.php?prodid=HD-396-WD&groupid=701&catid=14&subcat=1279
- http://www.overclockers.co.uk/showproduct.php?prodid=HD-366-WD&groupid=701&catid=14&subcat=1279
- http://www.overclockers.co.uk/showproduct.php?prodid=HD-379-WD&groupid=701&catid=14&subcat=1279
I know what power supply I want. It's only 380 Watts but I won't be gaming or overclocking so I'm sure it will be fine. (especially considering my current one is less than 200W I believe). It's the Antec 380W PSU, but I can't find a link for it.
Now for the interesting bits, that I really don't know that much about. For reasons that are too boring to say here I want a gigabyte motherboard. Now When it comes to CPU mobo and RAM I have no preference. This first motherboard here, I believe, to use the built in video ports you need a CPU with built in graphics,
- http://www.overclockers.co.uk/showproduct.php?prodid=MB-440-GI
A CPU such as this one:
- http://www.overclockers.co.uk/showproduct.php?prodid=CP-479-IN
Now I don't know how that combination would differ from another motherboard I've found which is cheaper, but with a more expensive CPU. I really haven't got a clue what the differences are here. Could I not use the built in video ports on this motherboard. Don't have a link but it's a,
"Gigabyte SKT-1155 B75M-D3H Motherboard"
CPU:
- http://www.overclockers.co.uk/showproduct.php?prodid=CP-444-IN
- http://www.overclockers.co.uk/showproduct.php?prodid=CP-418-IN
- http://www.overclockers.co.uk/showproduct.php?prodid=CP-404-IN
As far as I can tell those last three CPU's are exactly the same, why the different prices? Just different sellers? So bearing in mind what I'll be using this PC for, what's a good CPU & mobo?
And lastly the RAM. Most RAM I've found seems to be very samey. I really don't know what makes good RAM. I want 8GB dual channel, and I believe 1600MHz will do me just fine. With that in mind I'm considering:
- http://www.overclockers.co.uk/showproduct.php?prodid=MY-033-TG&groupid=701&catid=8&subcat=2429
- http://www.overclockers.co.uk/showproduct.php?prodid=MY-137-KS
- http://www.overclockers.co.uk/showproduct.php?prodid=MY-136-KS
Based purely on the brand and look of it, I'm leaning towards the first one.
Anyway that's my new PC. Any advice or tips or differences you spot between those components would be greatly appreciated. This is my first time trying something like this, and hopefully not my last!
CPU:
Match of the Day has finished now, so I'll take a look. Do you need peripherals to go with this?
