Advice for Hybrid GPU with Air cooled CPU
14 Feb 2009
I am planning on buying the new EVGA 3080 Hybrid whenever its available, but this puts me in a tricky predicament.
I am currently using a Dark Base Pro 900v2 case, with a Noctua NH-D15 air cooler for my 1700x (which I also plan to upgrade to Zen3 at some point). What would be the ideal placement for the 240mm radiator on the 3080 Hybrid?
I have attached a photo of what I had in mind which is basically using a push pull system and the radiator at the front of the case ( https://imgur.com/4UId0oi )
Edit: Or do I need to just bite the bullet and go for a Kraken x73 to top it all off?
script>
4UId0oi
4UId0oi
Honestly I would not use a GPU radiator as an intake. You are risking boiling everything inside of your case. The 3 series look like they are going to produce far more heat than your average CPU. I would put it as an exhaust. I don't know the case so I am not sure where else you could put it.
