I've not looked at PC components for years so could use some advice on parts for a new build. I have already bought the following:
AMD Ryzen 7 7800X3D
Crucial T500 4TB NVMe PCIe Gen4 M.2 Solid State Drive
Corsair Vengeance RGB EXPO 32GB (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel Kit
I was looking at this motherboard since adding a 4th ssd doesn't restrict the gpu to x8 speed:
Asus ROG Strix X670E-F Gaming WIFI (Socket AM5) DDR5 ATX Motherboard
Are there better alternatives to the motherboard for the money & what is Asus build quality like now as I'm seeing some bad reviews about them?
I'm undecided whether to get a 9070xt or pay the extra for a 5070 ti.
Please recommend a reasonable air cooler for the CPU that is quiet. I will likely change to custom water cooling later to make it quieter as I already have a load of old kit so would just need blocks and used to find gpu fan noise loud when they are under load so assuming that won't have changed.
PSU: I will use my old Coolermaster 850W
Case: I will use my old lian li case.
This will mostly be used for gaming at 1440p possibly with some video capturing / editing down the line.
AMD Ryzen 7 7800X3D
SAVE 30%
£500
(incl. VAT)
£350
(incl. VAT)
SAVE 26%
£370
(incl. VAT)
£272
(incl. VAT)
£150
(incl. VAT)
£310
(incl. VAT)
FREE DELIVERY
