- 28 Jan 2014
Hi guys,
So I had a P8P67 Pro die on me a few months ago and I am finally getting around to working on replacing it. Problem I am having is that the only new LGA1155 boards I can find are fairly entry level ASRock ones. The rest are mostly used for this socket.
So I basically was wondering if anyone had advice on either buying used board (ie from amazon) or if you guys knew anywhere I can still find a decent ATX LGA1155 board from. Im limited by budget (uni student) which is why I am trying to replace the board and not just build a whole new system.
Cheers
Cheers
