Hi guys, i was woundering if anyone could help me, im looking for a case, and what i want is one that has decent air flow, i dont mind noise, (within reason!). but i just want one that is designed (as in i dont need to take a dremel to the case!) to hold lots of fans that are well placed (would be ace if it comes with them!), inside the case i will be wanting atleast..
1 external 5 1/2
1 external 3 /12
2 internal 3 1/2
all cooling in the case (eg on cpu, gfx, nb) is fans only, so i want it to be as cool as possible
MAX dimensions are
Depth: 50cm
Height: 55cm
Width: 32cm
any suggestions? also my budget is around the £40 mark idealy but i can strech if the case is perfect for me (stech means upto £80 maybe)
i know im asking a lot but its worth a shot eh
cheers
1 external 5 1/2
1 external 3 /12
2 internal 3 1/2
MAX dimensions are
Depth: 50cm
Height: 55cm
Width: 32cm
cheers
