Advice if its worth upgrading monitor
15 Jan 2014
Hi there,
I currently have a HP 4k monitor which I play with my Xbox series x. It plays 4k UHD at 60 MHZ, no dolby vision or HDR 10 etc I don't have much knowledge about monitors as you can tell.
My question is purely from a graphics perspective as I'm quite happy with the 60mhz.
So is it worth me upgrading to a HDR10 or dolby vision for better graphics? If I did I would only have a £350 - £400 budget
too.
I would also need to have a monitor or TV which is no more than 32inch (just as its in the corner of the front room)
Thanks
Even for your Series X upgrading to a 120hz monitor alone will be a bigger upgrade to your experience than basic hdr on a monitor that doesn't even support it well enough. I'd recommend saving up and waiting for a hdr 1000 at the very least monitor. I had a hdr 400 4k 120hz monitors and the hdr was useless.
