oopsie i just ordered from this seller. 2 x blocak, 1 grey and 1 red.
http://www.ebay.co.uk/itm/250703183702?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
is that the same stuff or should i cancel?
It looks te same stuff to me, but I haven't had any experience with using it myself. Seemed like too much effort!
I warn you, it will take a lot of time to do it, make sure it's tought or it'll be too saggy and won't look very good. You also still need heat shrink
E: off the top of my head, MDPC stuff is something like 4mm so it should be fine. I had a quick measure of some of mine and it seemed to be around 4 mm, ofcourse, paradoxes should stretch more. I suggest you get a second opinion in this though as I am not 100% certain
